Rivo Plus
€1 299,00
The Rivo Plus builds on the acclaimed Rivo model, now featuring a dedicated ASIC for enhanced S/PDIF and AES-EBU outputs and upgraded MEMS clocks in the USB HUB IC. This delivers pure digital sound and seamless connectivity for audiophiles.
Includes all Volumio Premium features
El precio incluye gastos de envío, derechos de importación e impuestos de venta.
Envío gratuito Hecho en Florencia
Envío gratuito Envío gratuito
Devoluciones en 30 días Devoluciones en 30 días
Añadir a la cesta... El artículo ha sido añadido
OPTIMIZED CLOCK STABILITY
Upgraded MEMS clocks in the USB HUB IC enhance reclocking and signal integrity at the USB DAC port, ensuring superior jitter stability and consistent audio quality
I2S/DSD OVER HDMI CONNECTIVITY ADDED
I2S/DSD over HDMI interface offers optimal sonic performance for some external DACs compared to S/PDIF, AES-EBU, and USB
APOYO ESPECÍFICO
Asistencia personalizada para ayudarle en todo, desde la configuración hasta la resolución de problemas. Siempre a su disposición.
THE ULTIMATE DIGITAL TRANSPORT
The Rivo+ is the enhanced version of our award-winning Rivo digital transport. Engineered based on user feedback, Rivo+ elevates the already excellent qualities of the original.
Key upgrades include a dedicated ASIC for cleaner S/PDIF and AES-EBU outputs, improved MEMS clocks for lower jitter, I2S over HDMI connectivity for compatible high-end DACs, and a 12V trigger to power on/off other components.
If you demand the pinnacle of digital transport performance, the Rivo+ is the solution.
ENHANCED AUDIO VIA I2S/DSD OVER HDMI FOR DISCERNING LISTENERS
The Rivo+ features a dedicated ASIC to generate the S/PDIF and AES-EBU output signals, offloading this crucial task from the CPU. This specialized integrated circuit is designed to produce these digital output signals with uncompromising precision, free from any potential interference or jitter introduced by the main processor.
Powering this dedicated ASIC is a high-quality MEMS (Micro-Electro-Mechanical Systems) clock, which provides an exceptionally stable and low-jitter timing reference. Coupled with low-noise voltage regulators, this enhancement to the RIVO+ ensures the output signals maintain the utmost purity and refinement.
DISFRUTA DE LA MÚSICA DE TUS FUENTES FAVORITAS
Rivo+ lets you stream from your favorite music services
Trae tus contenidos desde unidades locales o conectadas a la red y reproduce radio por Internet
ENGINEERED FOR SIGNAL PRECISION
Upgraded MEMS clocks in the USB HUB IC enhance reclocking and signal integrity for Rivo+ especially when connected to the USB DAC port. This delivers exceptional jitter and frequency stability, reducing susceptibility to temperature changes and aging for consistently high-quality audio output.
FÁCIL CONFIGURACIÓN
Empezar sólo lleva un par de minutos con las aplicaciones oficiales para iOS y Android de Volumio .
FABRICADO EN ITALIA
Todos los productos de Volumio se diseñan y ensamblan en Florencia, Italia.
ROON READY
Todos los productos Volumio cuentan con la certificación Roon Ready de Roon Labs. lo que permite una integración perfecta con Roon.
MÚLTIPLES OPCIONES DE CONECTIVIDAD PARA EXPLORAR
S/PDIF and AES-EBU outputs generated by a dedicated ASIC with low-noise power supply + I2S/DSD over HDMI interface for optimized connection and enhanced audio performance.
VOLUMIO PREMIUM INCORPORADO
On board, the Rivo+ is the latest version of Volumio – Volumio AI- that incorporates Supersearch an AI-powered search function that is meant to optimize your music discovery.
Volumio OS dispone de una función multisala que crea un entorno integrado con otras estaciones Volumio de su hogar.
INCLUIDO EN LA CAJA
  • Volumio Rivo+
  • NFC Information Card
  • Fuente de alimentación de 5 V, 3 A
Audio
Digital Coaxial S/PDIF
Audio Output, up to PCM 192kHz/24bit and DSD64 via DoP
Digital AES/EBU
Audio Output, up to to PCM 192kHz/24bit and DSD64 via DoP
Digital I2S over HDMI Output
Audio Output, up to PCM 768kHz/32bit and DSD256
USB Output
Audio Output, up to PCM 768kHz/32bit and DSD256 (via USB DAC)
Alimentación y conectividad
Puerto USB DAC
1x USB 2.0
USB
1x USB 3.0, 1x USB 2.0
LAN
Gigabit 10/100/1000M
Inalámbrico
Wi-Fi 802.11a/b/g/n/ac, 2X2 MIMO con RSDB
Bluetooth
5.0
Información adicional
Formatos admitidos
DSD, WAV, FLAC, Alac, Aac, Vorbis, Mp3 and others
UPNP DLNA
Renderizador compatible con Open Home
Servicios de apoyo
Airplay a través de Shairport Sync, Spotify & Spotify Connect, TIDAL & TIDAL Connect, QOBUZ
Plugins disponibles
Youtube, Squeezelite, Radio Paradise, Podcasts, Pandora, Fusion DSP, Roon Bridge, Soundcloud, Mixcloud
CPU
Amlogic S905D3, cuatro núcleos a 1,9 GHz
RAM
2 GB DDR4
Almacenamiento interno
16 GB EMMC
5V, 3A
Diseño
Diseñador
Design Narratives Ltd.
Pesart
2,25 kg
Dimensiones
27x15x5 cm
Manual del usuario
Download Volumio Rivo+ User Manual Below:
Volumio Rivo+ Quick Start Guide Below:
Reseñas
